PCBFeature request: add trace length offset for component pins
2025-04-28 11:17:11
Some IC's like the Texas Instruments TUSB7340 (PCIE-USB3 host) specify in design documentation that the trace length should be compensated for externally using snakes.
The current tooling works very nicely to match trace length, but there is no way to specify the offset for internal ic bond wire lengths.
I would like to request the option to specify "internal chip bond wire length" on a per-pin base so the length matching tool can be used without manual calculation required.
By default, this value should be set at 0
