PCBMystical ratlist
2025-12-17 09:22:20
Hi, using the STD version.
I’ve made a schematic and a corresponding PCB layout. Done this many times before with EasyEDA.
The problem is that there is a ratline remaining in a net with quite few components. It leads far away from the actual board and has no trace or components at the end. Just a ratline ending nowhere however much you zoom in.
It has a name (+5 V). I removed all traces and connections with that label in the schematic and PCB and still the same ratline is visible with the +5V label. There are nothing with that label but the ratline. I can’t find a way to remove it.
Yes, I've read tutorials and do not like to bother other people but....
Regards
Harri Vanhala
